Hyd leak IH584
old
So this once way to hot 584 has a hyd leak coming form what looks to be the end of the steering cylinder. Does not appear to be the cylinder seals but the end piece of the cylinder. So does that sound right and if so how?? Thanks
The shaft is hollow-you can hold the fitting end with a wrench,and unscrew the fitting,and the yoke,and is said below,there is an o ring on each end.I just rebuilt 1 of these the other day.Mark
If it melted the rings out of those fittings you're better off take that cylinder off from rebuild it because it probably took the packing out on the piston out to and the seals on the end of the shaft the kid ain't that bad price
I have the I-T IH202 manual but it does not show the cylinder it self at least not for the 2 wheel drive tractor. This tractor I have steers well just has a good bit of a leak out of the end of the cylinder
