TractorLinks.com
Show Parts for Model:
Hyd leak IH584
old
10-11-2017 21:31:08
So this once way to hot 584 has a hyd leak coming form what looks to be the end of the steering cylinder. Does not appear to be the cylinder seals but the end piece of the cylinder. So does that sound right and if so how?? Thanks
ihtimmy
10-12-2017 08:59:11
 Re: Hyd leak IH584 in reply to old, 10-11-2017 21:31:08
Do you need pictures of this tractor I took some on our 684
old
10-12-2017 09:11:02
 Re: Hyd leak IH584 in reply to ihtimmy, 10-12-2017 08:59:11
I have the I-T IH202 manual but it does not show the cylinder it self at least not for the 2 wheel drive tractor. This tractor I have steers well just has a good bit of a leak out of the end of the cylinder
ihtimmy
10-12-2017 08:49:44
If it melted the rings out of those fittings you're better off take that cylinder off from rebuild it because it probably took the packing out on the piston out to and the seals on the end of the shaft the kid ain't that bad price
Mark Robke
10-12-2017 04:17:17
The shaft is hollow-you can hold the fitting end with a wrench,and unscrew the fitting,and the yoke,and is said below,there is an o ring on each end.I just rebuilt 1 of these the other day.Mark
caterpillar guy
10-12-2017 02:11:05
The end will unscrew off the end of the shaft. or the fitting if it is the other end of the shaft. Both have o-rings
ihtimmy
10-11-2017 23:10:39
Orings or a kit
