transtar61
I have a farmall 300 what i was wanting to know is . When i'm going to stop push in on the clutch when in gear on the high side of the TA the tractor will not roll with
clutch pushed in but it will roll on the low side with clutch pushed in . Do i need a TA ajustment other than that TA works fine when driving. Also i have a little gear
oil that leaks from the 2 holes on the TA housing i'm using hy -tran in the trans. Thanks
