My IH Cub has a Zenith 13794 / 715230-91 that I rebuilt about 2 years back and its been running pretty good until now. It will run for a while till it gets good and hot and then starts sputtering like its running out of fuel then will die. Sometimes I can get it to stay running by playing with the choke but most times it will die. It usually starts right back up and repeats the issue. It has always burned rich it seems since I got it two years back.
I took the carb off and cleaned it but don't think the float is adjusted right. Can someone assist me on the float adjustment dimensions and how to measure and set it?
I have cleaned the fuel bowl, installed new screen, and even changed out the coil. Any other things that may be causing the problem? I used this tractor a lot to mow around my property and need it back up running.
Thanks
Thanks
