300 vs 350 head. (gas)
Gary Mitchell
I have a 300 gas head laying around and got to wondering if it was the same as a 350, super H, etc? Anyone know? gm
Hope I remember numbers correct without looking. 361179R1 was used on 300 and 350. No drilled passage for ventilation to air cleaner intake like H and SH. 361179R1 used a valve cover with opening to air intake pipe. Valves a different length than original H and SH heads. Also a number 362533R1 head that will work on H through 350 can be found. Has drilled ventilation passage like a H or SH or passage was plugged and 300 or 350 valve cover used on those tractors. Head used the same valves that a 300 or 350 gas head did.
