I just installed a known good battery ignition distributor onto a IH 424 gas tractor. This tractor has a C-146 engine. I am getting spark and it will hit but it turns over a good bit before it will. I think I have the timing close but not quite right. I set the timing by turning engine to Top of piston on compression stroke at plug #1. I then looked at the rotor button and it was pointing at 6 o'clock. My uncle installed the distributor today and I got home from work and found it this way. The #1 plug tower points to about 2 o'clock. I then removed the distributor and the distributor-to-governor housing and then removed the gear in the back and then turned rotor to 2oclock position. I then tried to match up the gear governor drive the best I could and reinstalled it. Bolted everything back up. Compression is 120-140 on all cylinders
Please help!!!
Please help!!!
