TractorLinks.com
Show Parts for Model:
Rad cap
dcpky
09-19-2017 17:03:55
Have a 1948 Farmall C no water pump wanting to order rad cap do I get pressure cap or non cap ? Thanks Also it has a zenith carb all I can find is made in USA B5 want to order a good kit don't no what to order
Jim Becker
09-20-2017 09:42:27
 Re: Rad cap in reply to dcpky, 09-19-2017 17:03:55
Diverging from the original question, but the Super A of that time did not have a pressure cap. It used the older style cap that fit the same as the gas cap. The Super A1 had a pressure cap.
BarnyardEngineering
09-20-2017 04:31:17
The radiators where the fuel cap fits are only on the early-early models of A/B/H/M. By the time the C came around they all had the modern automotive radiator cap.
I believe you can use a pressure cap, but no more than 7PSI.
Tractor supply also sells a non-pressure radiator cap, also advertised as an oil fill cap for a Ford N-series.
Janicholson
09-19-2017 18:52:58
The pressure cap looks and is like automotive caps of the era. 7 PSI it will have cam lugs on the outside of the lip. If it is non pressurized, it will be much bigger and is very similar to the fuel cap, which has its cam lugs inside the seal ring. Jim
