No joy...
Replaced the new coil which was 12V with a 6V, the exact IH part number replacement. Got spark across the points, but no fire. Replaced the new condenser with another new one, won't fire. Replaced the wire from the coil to the new distributor cap, good connection and no fire.
Got gas to the carb. Drove the tractor to the spot where I'm working on it, no issues, only replaced plugs, points, i.e. tune-up parts and the tractor won't fire or even misfire on any cylinder.
I'm thinking the plug wires are not going to the right plug - though everything is wired per the manual - pic attached.
I understand the firing order off the distributor and the cap is marked as such. Question is - is the 1-6 sequential plug numbering on the engine correct per the manual left to right? The distributor cap is what mixes-up the firing order - right?
Similar post on RP
Thanks!
Bill
Similar post on RP
Thanks!
Bill
