led headlights
rray
My 67 rowcrop 504 had one headlight missing when I got it and the other was broken. I am thinking I would like to replace them with led headlights. I do not know what would be comparable to the old sealed beams. Any suggestion?
You can put LED based Lights that are whole assemblies, or put LED bulbs into the OEM housings. Either one is fine. Wire them the
same as the originals. Jim
I only have one of the OEM housings. I am looking for a complete assembly that would have a similar pattern and distance as the original.
Here is a helpful hint. If your tractor is 12 volt. The bulb would be
a 1156. The newer ones would be a sealed beam. Now if you go on Ebay
look up the DRL LED bulbs for Volkswagon. These are daytime running
lights. Not too expensive and are direct replacement for 1156 bulbs.
Also they are screaming bright.
