gentlemen, I have a 41 M that seems weak on power, won't pull itself in 5th gear. She has good compression, rebuilt carb, engine runs fine and revs up fine with no load, but when under load even just going up a small rise she loses rpms even in first or second gear. I replaced magneto with distributor a while back as I couldn't get timing right with the mag, thought it would be easier to put dist on rather than pull hydraulic pump and move gear mesh a couple cogs to get timing closer. Timing now is right on. wondering if I have a governor problem or if maybe advance weights in distributor might be the problem. I haven't opened the governor yet because of power steering pump cobbled together over it. Thoughts?
Dick ND
Dick ND
