TractorLinks.com
Show Parts for Model:
led headlights
rray
09-12-2017 09:44:22
My 67 rowcrop 504 had one headlight missing when I got it and the other was broken. I am thinking I would like to replace them with led headlights. I do not know what would be comparable to the old sealed beams. Any suggestion?
jeffcat
09-12-2017 12:51:40
 Re: led headlights in reply to rray, 09-12-2017 09:44:22
Here is a helpful hint. If your tractor is 12 volt. The bulb would be a 1156. The newer ones would be a sealed beam. Now if you go on Ebay look up the DRL LED bulbs for Volkswagon. These are daytime running lights. Not too expensive and are direct replacement for 1156 bulbs. Also they are screaming bright.
rray
09-12-2017 11:20:30
I only have one of the OEM housings. I am looking for a complete assembly that would have a similar pattern and distance as the original.
BarnyardEngineering
09-12-2017 10:54:37
Nothing will be comparable to the old sealed beams. Anything you get will be much much better.
Janicholson
09-12-2017 10:01:43
You can put LED based Lights that are whole assemblies, or put LED bulbs into the OEM housings. Either one is fine. Wire them the same as the originals. Jim
