Rich Perry
I am trying to find the dimensions of the outer axle bearing on the '50 H. I haven't torn it down yet and am trying to get all the parts prior to working on it.
Part number should be ST328. I found a cross reference for a ND68466 D. New Departure is no longer available and I can't cross reference from their number. If anyone has a Timken or NTN number I could work with that would be good also.
I got a quote from a bearing service but I want to double check the dimensions prior to purchase.
The dimensions of their bearing is 65mm ID x 120mm OD x 23mm wide.
Thanks in advance,
Rich
Thanks in advance,
Rich
