W-30 Rear wheels....
banjoman09
Anyone had their "rear wheels" off their IH tractor- maybe the 10-20 and W-30 are the same. I have the two nuts off- washer and felt seal...(no bearings I guess) are they on a spline shaft? Hook other tractor to wheel with chain and take off? Thanks.
Do you know which puller? or where to buy one? I have several 2 and 3 arm pullers but it appears this wheel will need a puller you can put two 5/8 bolts thru the two slotted arms and back thru the two holes in the wheel; like a "steering wheel puller" only a whole lot bigger! Any ideas?
Never mind - I actually started thinking tonight and put a "Jack" behind the wheel and pushed it off...amazing grace!
