farmall pete
I presently have a single remote valve on my 656. It is the red one in the pictures. Both of the white valves in the pictures came with the 656, and were mounted on the fender to control a loader. I want to stack the red one and one of the white ones so I have 2 rear remotes.
Each of the valves is a little different, although they are all the same vintage. The bolt holes and orifices all line up. Why are the rear cylinder sleeves different lengths? Why is there a plug above the actuator on one of the white ones? Can I use one of them in combination with the original, red one?
Thanks for any advice you all can give me!
