300 on steel question
Charlie M
There is thread below with a 300 with steel wheels. Was factory steel an option for them or would someone have added them. Does H steel fit them. I've never seen a tractor newer than the letter series with steel unless someone had them made. The Mennonites around here around here have steel on some pretty big tractors but they definitely had to have them made by someone.
Steel is listed in the F-300 parts book and the F-300 owners manual. H used the same diameter rear axle and front spindle size as the 300, unless a late 300 is found with the optional 2.750 diameter axles.
