Southtowns27
Hi all. We've got a 706 with a surging governor. We never really noticed any issue with the tractor, probably because we never worked it very hard. Earlier this year we hooked it to a 9'6" discbine. It surged constantly from 1600-2300 RPM. I ended up having to crank in the bumper spring screw nearly the entire way to get the surging to stop just so I could cut the field. With the screw cranked in that far, I basically had no governor response to load change. I had to control it all manually. It was a pain in the rear, but I got the field knocked down. I also checked and adjusted the governor to carb linkage as per the manual with no change.
The throttle also seems to have a stiff spot in in. No linkages are binding, it seems like it's built that way. With the throttle lever at idle, it looks like there's a finger pushing the governor arm forward. As the throttle lever is advanced, this finger moves out of the way allowing the gov arm to move. It doesn't seem like a linear action though, it gets to a point where the finger just drops out of the way and the governor arm snaps. Is it supposed to be that way? If not, what's the fix?
So all that said, I'm thinking the governor needs to be rebuilt. Is there a known reputable shop that fixes these things?
And as an aside, the discbine also brought to light that the cooling system needs some attention. Is there a good aftermarket (not Chinese) radiator available for these things? Or should we get the original recored?
Thanks in advance!
Thanks in advance!
