There were autolight 386 plugs in the Super A when i got it. It has a mag so I put 3116 in because they're non resistor plugs and i guess that's what you need to use from what I've read but are these hot enough? I've read that if your plugs are not hot enough you'll have to use choke to run smooth which is the problem I'm having. I'm thoroughly cleaning the carb again but I'm wondering if plugs might be an issue too?
