Farmall Cub Transmission
Got my 1948 Farmall Cub out other day took for ride through neighborhood havent had out in 5 months noticed oil leaking dripping in rd leaving its mark from the house all way down the hill and back 😣 As i had removed the belt pulley and forgot to replace the lower bolts around the PTO area. I used 80-90 Lucas in Tranny but replaced with 140 Sta-Lube stuff does the cubs call for certain type fluid?
I use regular 80W-90 trans oil in my Cub, except for the hydraulics which I use an approved IH/Case oil.
