So I have of had the cooling system put together but found the thermostat was sticking so have a new one to put in here in a little bit. But that is not the next problem.
I fired it up yesterday and noticed I had hyd fluid leaking out from under the steering wheel. So can I fix the leak by pulling the steering wheel off and then pulling a seal and then install a new seal??
I also tried to bleed the brakes but go no fluid out of the bleeder even when I pushed the brake pedal down so what is up there??
Thanks
Thanks
