404 international
pinball
I HAVE A LEAK ON THE RIGHT SIDE OF MY REAR AXLE. I GREASED THE SEAL BUT IT SEEMED TO MAKE IT WORSE. SUSPECT SEAL IS BAD. I SEE THERE IS A LARGE NUT IN THE CENTER OF THE HUB. I KNOW I HAVE TO REMOVE HE WHEEL . LOOKS LIKE A SPLINED SHAFT GOES IN TO THE HOUSING. SUSPECT THAT I HAVE TO REMOVE IT BEFORE I CAN GET THE SEAL HOUSING OFF. SO CAN SOMEONE TELL ME WHAT I HAVE TO DO TO REPLACE THAT SEAL. THANKS NORM 404 INTENATIONAL TRACTOR
