IH584 air filter pipe. Where to find one
old
So this once way to hot 584 needs a new air filter pipe. The old one which I guess was plastic is not on it so I need to find one before I can run it much. New radiator from ASAP is on it now and I'll be filling the cooling system after I take a few minutes of break time and fire it up and see if things work as they should.
Thanks
looked at Case IH parts pages. If this is what I think it is, Intake air hose, 63.50mm ID, 69.85mm ID x 228.6mm. Appears to be a partial U shaped hose with 1 leg longer. Part No. 3113612R1 you might try search on part No. , hope this helps. Leroy
If I remember right I 584 did not have that on there I could be wrong but it would be marks on that were would go
From what I can tell it has a pipe that goes from the intake manifold up to the air filter box and then it also has 2 other hoses coming off of it. Since I have not seen how they go I can only take educated guesses as to what is what
I have buddy 684 I check it out it Does not have one he bought it brand new it was a left over on 674 it was plastic
Not sure what your trying to say here. I know it has to have a tube of some sort going from the intake up to the air cleaner since the air cleaner sits at least a foot above it and of course due to the fire it is not longer on it
I'm just saying that his did not come with one and it's not that important on the older tractor they went up in a baffle in
the hood it should be the same thing in a 585
(quoted from post at 18:32:08 09/02/17) I'm just saying that his did not come with one and it's not that important on the older tractor they went up in a baffle in
I don't think you two guys are talking about the same thing here.
The tube that connects the air cleaner to the intake most certainly *IS* important.
The tube I am talking about goes form the air intake to the filter and that one is a must have or you have no air filter on it
