58' 350U traction control link
dbflyrod
New User
I've been searching for a traction control link. The piece that hooks up under the tractor and connects to the traction control adjuster handle. I thought I had one located but it was out of stock. I do have capability to build one so I was wondering if anyone might have dimensions like the distance from the center of the front mounting point (1" diameter pin) to the contact point on the cam (sometimes referred to as the teardrop part). Also the distance from the center of the front mounting point to the adjustment handle attachment hole. I have all other parts except the link.
thanks
Thank you, I guess I need to learn how to post a pic, in the mean time here is the PN I got off Wengers. When I clicked on the link to add it to my cart it was not in stock. I'm not sure if this is a IH part # or not. PN 522737R
The part is shown here. (#9 I think ) The reality is that the traction control does not really work very well. I give it a 2 on a 10 scale. If you get one, fine if not just make a duplicate that moves the Bracket, Ball pivot through its range when moved up and down the notches in the adjustment D handle. Jim
Untitled URL Link
522737R91 is for a high utility or a Farmall. 522782R11 was for a regular utility. If a number is found on link it would probably be 522782R1.
