Rustred quick question
BigTone
The well jet and economizer jet won't come out, the screw heads are destroyed but the passage ways look fine so i wasn't going to new with them . I'm assuming they have gaskets so when I soak this carb later today it's probably going to eat those gaskets away. Think this is going to create a problem? I'm a little nervous about pressing a screw driver in there and pulling the well jet out at least.
it may be ok to leave it alone as a lot of times trying to remove stuck parts makes bigger problems. i have a few times left the seat in and soaked a carb and it didnt seam to affect the gasket. that gunk is strong especially when new so things may go well.
