International 350 replace throwout bearing
bmumph1
New User
I'm in the process of replacing the clutch in my international 350. While I'm doing that, I'm also going to replace the throw out bearing. I have the tractor split and the new clutch is ready to go in. I just can't figure out how to get the throw out bearing off the yoke. how does the bearing come off the yoke?
Thanks,
NOT sure what you are calling a "yoke".
Are you replacing just the bearing, or the bearing and "sleeve" assembly?
Are you trying to get the bearing off of the sleeve, or the sleeve and bearing out of the fork?
Here's the picture of the yoke with the bearing.
Ok. I wasn't sure if it would just tap off or if there was some trick to remove it. I didn't want to break the sleeve. I'll give it a try tonight.
Thanks,
