Been working a Farmall 400 that had camshaft & nut failure. My Dad had taken the big nut off, shaft off & the power steering unit off while I was at work. I got the engine back together & running good. I started to put the steering system back in.
Noticed the nut on the end of the shaft was loose with a cotter pin, I'm assuming the nut is to be tight? Cant find any info in IH manuals.
Is the shaft/worm gear suppose to be installed all the way in the bolster housing? Then tighten the cast nut till its tight?
Thanks
Thanks
