Dave Westlund
I purchased a M Farmall that had run into a misfortune and damaged the radiator, grille, hood, upper steering shaft, throttle, and gas tank. I was able to start it and drive in on to the trailer to bring it home but I could only run it for a very short time. Now that I have it home I took a compression check and the 4 cylinders read 103-107 dry and 105-113 wet. The tractor did startup quickly to load but didn't pay much attention to anything else at the time. Is there anything significant showning up with these numbers? I'm not sure what a fresh engine would be? Your comments would be much appreciated.
Dave
Dave
