Lumbersawyer
- Location
- Grand Rapids, MN
My son and I have started to work on my fathers 10-20. It sat since my dad died in 85. Our problem is once we got the motor freed up and ready to run, the tractor will only run if the choke is pull half way on. I cleaned the carb, replaced gaskets, re-sealed the cork float, all the normal stuff. I noticed the needle and seat is the same used on my John Deere GP Ensign. This three part Ensign is a little different from any carb I have worked on. The adjusting of the jets do very little if anything to the running of the tractor. Dad had this tractor in the field plowing all day before he died so I know it ran well. What would make it need the choke pulled to keep it running?
I have a spare carb but the throttle linkage is different. So I used the top two sections of the spare and reassembled a new carb. It is the same if not worse...
ANY ADVICE would be appreciated.
