Yes and no. It will fit either way but the 460 pump has smaller pumping plungers than the 560. So, if you put a 560 pump on a 460 it will be over fuelled, and vis versa other way around.
I should have also said, I always wanted to install a 560 pump on a 460 just to see how it performed, started, power, smooth running etc. Never had that opportunity but I would not be afraid to give it a try.
