Horizontal hitch bolt size?
Cecil09
Sorry guys I store the tractor somewhere other than where I live at the moment so I can't really measure. I am trying to replace all of the horizontal bolts for the hitch brackets that sandwich the axle. Does anyone know what the length is on them? I know they are 3/4" but not sure on length? They have all been pretty beat up and I think some have been previously replaced because the threads are different on a couple. Thank for any help.
If it's the over and under axle for axle clamps 8 inches long. But if you use a regular hex head a little will need ground of two high spots on each side of head. Clean bolts will hold from turning when tightening but may turn in channel if needing to remove sometime. Original bolts have a special rectangular head. One of the eye bolts on each clamp needs removed when replacing bolts. Press or hammer pins out. But some take a lot of pressure to remove.
(quoted from post at 19:07:55 08/10/17) If it's the over and under axle for axle clamps 8 inches long. But if you use a regular hex head a little will need ground of two high spots on each side of head. Clean bolts will hold from turning when tightening but may turn in channel if needing to remove sometime. Original bolts have a special rectangular head. One of the eye bolts on each clamp needs removed when replacing bolts. Press or hammer pins out. But some take a lot of pressure to remove.
Thank you very much.
