Got a C I took the carb off to rebuild, in the process the cast governor arm snapped off at the clevis. I have a new one, and attempted to put it on today, but once I got the bolt out, there's not enough clearance between the gov shaft and the water pump housing to get the arm off. Took two long and two short bolts out of the governor, but the governor still wants to bind on the side closest to the crank. It will separate 3/8" or so with light pressure from a screwdriver on the outboard side, but as I work around the top towards the center, it gets tight. CNH parts breakdown is of no help. It's my hope to just slide the gov far enough forward to get the arm off the end of the shaft and install the new one, then slide the gov straight back out into place.
