IAtractorKid
Hey guys! So still slowly working on this IH 404 utility with a C-135 engine. Valve cover on the tractor was pretty beat and soldered in multiple locations. Tracked down a good used and installed it today after re-adjusting the valves again. Unfortunately the adjustment screws are hitting the valve cover....must have been what tore up the old one as well. Not all of them hit...all the screws look to be the same length. Any thoughts???? I am wondering if the valve seats are hammered into the head far enough, that the adjustment screws is set almost all the way out causing my issue. Is that even possible?
Need to check compression again and have not had any luck freeing the clutch. Split is in my near future!
