Ken Christopherson
Hello all. I just had a quick question. Does anyone happen to know if the PTO/Belt Pulley lever on the left (clutch) side of the tractor is just pressed onto the shaft with a keyway (I can see the key), or if there is also a set screw of any kind? I am assuming it is pressed on and just needs lubrication and a puller to remove as I cannot see any set screw. Reason I ask is mine has been torched in half at some point, and I would like to replace it with the in tact one on my parts tractor.
Let me know, if you know.. And thanks!
