I think the problem may be the generator. I thought it was OK because it charges 13 amp at full throttle when cutout is closed or when by-passed and jumped bat to armature. The generator was on a shops test stand a few yrs ago and he said it was OK after new brushes, (approx. 3-400 hrs. ago). It's only generating less than 1 volt testing armature to ground when cutout blocked open and that won't close the cutout. Also, it wouldn't charge when putting an inline diode in the circuit instead of the cutout. I used a digital and an analog meter to test. I thought I understood the generation system and I had or I have tried the things suggested by Jim, John,Pete & Gene. I would appreciate any thoughts on why the low voltage output when it will charge 10-13 amps. I think it to go to a shop again. Thanks -- wok
