Ncarolinasailor
My 2 1/2" socket came in today so I took a crack at getting the front plate and gears off. Everything went well (the locked up crank held it in place so a cheater pipe and minimal effort removed the nut). Once I got the front cover off I think I found what killed this tractor in the first place as the camshaft pulley nut was lying in the bottom of the front cover. It had sheered right off destroying the key and threads on the way off. As soon as the gears were removed the crank turns over fine but still no budge from the cam and every lifter seems to be locked into place. So this leads me to two questions...
1 - Is there a good way to remove the lifters and/or camshaft or will that be easier with the motor upside down with the crank out of it?
2 - What do you think caused the failure? I would think something overheated in the valve system and the camshaft locked up and inertia did the damage.
