Got a few issues to work out on my project Farmall 100 tractor. I pulled the valve cover to see if oil is draining from the rocker arm area and realized I didn't see a way for oil to get there to start with. I
did some searching around on the internet and it looks like what I'm seeing is the short stud holding down the middle of the rocker arm assembly is actually a hollow tube and allows oil to be pump through it
to the rocker arm assembly. Can someone confirm that is what its supposed to be. Mine has a solid stud there. It was in the tractor when I got it.
