Dave H (MI)
I dismantled and painted this tractor several years ago. Mostly it sits in the garage. Has never seen much run time since restoration. I have a job for it now so pulled it out, put fresh gas in, charged up the battery and fired it up. Only known issue with tractor is i am pretty sure the VR is not working. Tractor has running issues as follows:
Started good and sounded really good in beginning. Drove about a quarter mile down farm lane. No real issue. Came to a mild up grade in second gear, engine lugging and was going to stall. Took it out of gear, did not quickly return to full rpms. Finished hill in first gear, did ok. Not much power. Tried on level ground to use 3rd, did not want to do it. Nearly back to shed, in 2nd and on level ground tractor stalled and would not restart. Coil was cool. Restarted a half hour later but stalled pdq and now will not restart. Tractor just does not seem to have much power.
Any suggestions?
Any suggestions?
