IH 250A Industrial Tractor Loader Backhoe
pottedgold
New User
Hi I have purchased a ih 250a industrial loader backhoe. I am unsure which manuals to purchase for the tractor. Any help would be appreciated. I also am wondering what a particular valve on tractor is called. It is leaking and would like to order parts to fix along with manuals. Model # 1-250PH, Serial# 2340127B101380-X.
IH Industrials are kind of a red-headed step child around here so don't be surprised if you don't get a lot of responses. CaseIH equipment dealers don't carry parts for them unless they're common to a particular tractor, and then you need to know which tractor because they can't look up the industrial model.
All the IH construction equipment went to Dresser in the early 1980's, and I think now you'd go to a Komatsu dealer for parts.
As for the valve, what does it do when you pull the lever? Whatever it does, is what it is.
As the other form I said it is a 2050 loader for a 574 or 674 for the valve on the right-hand side as
the picture you showed it is in the book you can get parts for like the O-rings and that's about only
thing you can get
Hi the tractor is either 574 or 674 Diesel with a D-239 German Diesel engine. The only difference between a 574 and 674 was the
size of the rear tires and the injection pump power screw setting.
I noticed someone has replaced the pin in the left side of the loader boom with a bolt. Just make sure the bolt is the correct
size and is not too small causing the pin hole to be worn.
JimB
