IH 544 steering part - Help ID
RTR
Got this steering arm off of an IH 544 Hydro and I can't seem to match it to any of the parts listed on the Case IH parts website. I'm trying to find a replacement and need the part Number and description so I can ask for it at salvage yards. Do any of you recognize this part?
(quoted from post at 00:56:00 07/18/17) Asap has them in and used I have bought those those private from them part 379555R11 and
379553R11
What is the part called? Why don't I see it on the parts breakdown on the Case IH site?
Upper and lower lever and you will need part number 379554R1 x2 and 379748R1 X2
bushings I would get them for him ASAP tractor parts for less $260 I gave you the part numbers
you can call ASAP tractor parts of the look it up on the line and those bushings they go in the
middle and in the end of the levers are you Gotta do is call them and tell him those part numbers
and they can look it up
I have use their products and they are good part when I met new those are new part numbers if
you buy them through caseih you would probably pay another $250 more or 300
(quoted from post at 02:10:13 07/19/17) If it's the same as a 656 utility I have a junker in the back of the shop.
How much for both pieces provided they don't have any breaks or welds? Email at ihfarmallrtr (at) gmail
