Not IH BUT -I have a older Hobart welder with a 6cyl Chrysler motor. I decided to sw to 12V
and installed a resistor for the coil I though I would see if the 6V gen would charge it as
I don't use the welder very often. With the motor running it shows a 20A discharge(Amp
meter is wired correctly)If I grd the F it charges but things get hot and it puts load on
the motor. What would make it discharge.
Thanks
Thanks
