Zenith carb IH manual
BigTone
My c-123 block has a zenith carb, 9752 on the tag pretty sure it's a 61 or 161. The carb was disassembled, cleaned, but not put back together. I have the correct rebuild kit, 9752, but I would like to have a manual to help put it back together. I found a IH service manual for it but i also found what looks like the original manual reproduced. My question is, the block is a later replacement block so would the specs for the jets and the idle, mixture screws all be the same? Just wondering if any manual is better than the others,thanks Anthony
A cheap carb kit has poor instructions and a good carb kit like the ones I buy at O'Reilly's have a good instruction sheet. Walker brand kit and they cost around $20 and well worth it
