Hello Farmall guys! I have a 1950 Farmall H tractor - the only Farmall in my collection. It only gets started and moved around once or twice per year. It starts fine, and runs well initially, but after it warms up, it starts running rough, almost like it is missing out, but not consistent like one cylinder cutting out. It seems a bit like an ignition issue (I hate electrical problems...). Like maybe as simple as the coil getting weak when it warms up?? I simply haven't made time to work on it. (Did I mention I hate electrical problems??) I would like to get it capable of doing a tractor drive so that my cousin can mark that item off of his bucket list (he grew up on Farmalls).
I don't mean to be lazy by asking this question of you before I have even tried to work on it, but just thought maybe this might be something common to the Farmall H that some of you have run across before (I have not had one of my Massey's behave in this manner), and it could save me some time if I had some experienced Farmall ideas on where to start first. It is still set up with 6-volt system. Next time I plan to start and run it I will probably stick a different coil on it just to see if that makes a difference.
Please share your thoughts with me if you have ideas.
Thanks,
JB
Thanks,
JB
