Case IH parts look up
THolmer
OK. What am I doing wrong? When I go to the Caseih parts site and want to search a M farmall by model nothing shows up? If I type super m that comes up but not the M.
Thanks Todd
Messicks is where I always go if I want to look up parts -I haven't been to the CaseIH site in a long time.
Been there as well. When searching for model, type in Farmall and also 1939 1952 (production years). That will bring up the Farmall M as one of the model choices. That works for me at least - good luck.
I know you used to be able to type in Farmall. Wasn't that long ago I looked up parts for my B. This weekend I try to find a thermostat foe my MD and couldn't get it to come up. It didn't show me a option for 39-52. I was going thru the local dealer here. I did find letter series for Case.
caseman-d
For engine parts you have to put in the engine model like D-239 or 248 and such not the tractor since the engine may have been used in different applications. The D-239 was used in swathers as well as tractors. Some of the engines were used in combines cotton strippers and such.
The engine part is especially true for stuff made from 1963 on. I think most of the parts books for older tractors include the engine, but from the 06 series on up, the engines are listed separately.
Thanks for finally figuring out how to find the M parts book!.
Now that I know how to search for it, I see how things work:
It looks like the search algorithm limits you to 50 results, and does a "substring" search. Searching for "Farmall M" is the same as searching for "Farmall" because the M matches the M in Farmall! The first 50 results are the new Farmall compact tractors that are in production now, so it sorts by newest first.
having the same problem
look up farmall MV thats where im finding parts listing for the M
what im finding the difference is in the final drives and the wide front end.
again try using MV
bass
