We just got us an IH 584 Diesel to fix up and I have a few questions.
It has a 15 inch tire on the front and Tractor Data website shows that it should have 16 inch tires.
I need to buy some new wheel studs for one hub as someone installed some studs but tack welded them and they just popped right off. Would any of you happen to know the correct size?
Also, how involved would it be to remove the cab? I see bolts at the front and under the fenders but didn't know if there would be anything else to expect to remove or loosen. What all would I lose or have to replace for a standard open tractor conversion?
