Some idea of value on an SMD
Looking at an SMD with a Servis front blade. Needs
rear tires and sheet metal is rough but it runs.
Unfortunately not a TA tractor. Can someone give
me some idea of value?
2000.00-2500.00 as a start. to me im more interested in the originality aspect.
when the fenders are gone and tin work is beat up , tires flat , then they are not worth a lot. that may be too much also without a picture.
No more than 1500 max tires will cost you 800-1600 depending brand size etc junk tin work etc means tractor
Most likely not taken care of
800-1200 would be as high as I would go. Depending on whether it is a stage 1 or 2 would determine where in that range I would be. Pics would help to give a better assessment.
Thanks for the replies. This one is not for me. I know with nearly any amount of restoration, amount invested can easily go way beyond the value...and this one is starting out too high. I have too many of those already.
Pawnee, OK. Saw the posting on facebook. I have no clue if it is Stage I or II. The pic I saw showed it still has fenders but the grill is red and white....not all red.
The facebook page is "Farm Tractors and Implements of Oklahoma".
(reply to post at 12:48:28 06/26/17)
You lost me at...Needs rear tires! I looked at several around here and online and after pricing tires backed away from those needing rear casings. Finally found one with good rear rubber, replaced the fronts for $200. New rear tires cost more then tractor.
