Trent Couch
I have been working steadily on rebuilding my
Farmall m transmission I have got all the bearings
from the front of the transmission to the bull pinion
replaced now I am left with the axle bearings. I want
to replace the inner axle bearings with the roller
style used on the 560's as I mentioned last year and
y'all were really helpful giving me information. I
know that 375215R91 was the original part number
but is no longer available through Case, then the
new part number that was gave to me was
529427R91 and I found the part on Case's website
put it in the cart and got busy doing some other
things but now have devoted my time back to
restoring this ol' girl, but now after looking closely
529427R91 is listed as 65mm ID X 120mm OD
which would be for a 2.5" axle so this bearing would
not work I'm assuming? I have tried browsing the
internet trying to find a match but still am having no
luck I need the 70mm ID X 120mm OD bearing that
was 375215R91. Any help is appreciated! I will
include some pictures of the rebuild I even went to
the extent of replacing the bushings in the reverse
idler gear.
idler gear.
