IAtractorKid
Ok guys so I replaced the sleeve carrier bolts and tightened them; side to side chatter in the clutch release shaft is gone.
Removed the 4 bolt wavy coupler and spaced it out as it should be, so it is now correctly installed. Readjusted the clutch pedal free travel and the tractor again shifts nicely.
Clutch feels good, but am still getting a little vibration in the pedal. Also have a little chatter from the clutch area...mostly in reverse.
Go ahead and release the throw out bearing or what do you guys think? Thanks for the help!!
