Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall M Questions
ih560
06-19-2017 16:04:41
All you have to do is pull the sleeves, run a hone over the block and the pistons will fit right into the parent bore. You can get some rings made pretty cheap to fit into the counterbore at the top of the cylinder so you don't lose any compression there, or have the hot spots. Machine the rings to be a slight press fit into the block and be flush with the deck. I have done this myself and it works fine. If you don't have a lathe, you could probably get a machine shop that isn't too busy to make a set of rings for pretty cheap. The first set I had made (before I got my own lathe) cost me $40.
