Weight of wheel center and wheel weight
RTR
Does anyone know what the heavy cast wheel center weights on a Farmall Super A, 100, 140, 140 tractor. I'm not talking about the stamped wheel center ......the heavy cast center on the right side. Also the weight of a rear wheel weight for the same tractor.
The cast center while I cannot tell your the exact number it is in the 250-300lbs range. The wheel weight it self is around 150lbs
