No luck removing pulley.
jimdog
Trying to remove the front pulley on my 826D Farmall.The book says after you remove the three bolts the heavy washer and that ring then tap the pulley with a plastic hammer and the pressure ring should come out.I have been putting penetrating oil on it,still on luck.ANY Ideas?
Thanks for any help.
Just do not put a puller on it. Time to hit harder all the way around to get the attention of all those wedge rings, and note their positions.
