urbancase
guys my tractor was delivered this morning,took it off with my 1845c case skidsteer from a drop deck trailer. now I had a chance to look at it this is what I got. its late model by he dash it is different from my 986 how ever looks like some of the sensors are not working, the 1000 IPTO does work but tractor does not move and I bought this broke so it not a surprise. will not do anything in any gear and the shifter from park to reverse will not go in either side. the motor is a reman and was done by SRC company in Springfield has 6200 hours on tach . needs a cab kit on the inside but outside of cab looks good as little rust. motor does not smoke and no weights on the front but I do have some I can put on but not a full set. I thinking ring and pinion as it had stop in the field under load I was told. what do you guys think good winter project.
